Blows black smoke?
2,400 MILES • 4 CYL • FWD • AUTOMATIC
LISSALEA
The other day my equinox that I just purchased in Dec of 2009 was blowing black smoke from the backend. And then it would not accelerate past 9 or 10 mph and when idling it just decided to accelerate on its own. No check engine light came on. Took it to the dealership I bought it from and they have informed me nothing it wrong with it. How can that be? Does anyone have ideas what this could be? I am afraid it will happen again and the only thing I can think of that I did with the vehicle is that they did the 1st oil change on it about 2 months prior to this. Please help!
Jun 14, 2010 at 4:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Most likely an intermittent problem and Dealer was unable to verify. The accelerator pedal is not a cable it is a electronic sensor so suspect problem maybe there.
Has this occured only once? Did you get a repair order? if not go back and get on record so if persists you have a case on record.
Hope this helps
Thanks for donate
Jun 14, 2010 at 6:07 AM
LISSALEA
The accelarating issue has only occurred once but the black smoke did it about a month before. What could the black smoke be from?
Jun 14, 2010 at 6:47 AM
DOCFIXIT
  • 18,828 POSTS
Very rich fuel mixture maybe leaking fuel injector,faulty PCM,temp or O2sensor
Jun 14, 2010 at 6:55 AM
GSNAPPERS
I had just driven about 250 miles and was going up a steep grade travelling about 85 MPH when I noticed smoke in my rear view view mirror. I looked in my side mirror and black smoke was seemingly coming from the exhaust. The car was not overheating and the engine light did not come on I did not notice any type of smell. I lowered my speed to 65 MPH and turned off the air conditioner for a minute or two (it was about 95 degrees outside). The smoke subsided so I turned the A/C on and increased the speed to 70 and it smoked again. I repeated the same and smoke went away. I had cleared the grade by this time so continued to 75 with the A/C with no more smoke.
Do you have any ideas on what would cause the smoke? I have never noticed smoke coming from the exhaust before.
Jul 6, 2020 at 10:10 AM (Merged)
  • 110,246 POSTS
It sounds like you may have an injector shorting out but to be sure this guide will help us find the problem
https://www.2carpros.com/articles/engine-black-smoke
TURBOJAY
I had this problem they had to replace the PCM with a used unit FYI.
Jul 6, 2020 at 10:11 AM
