2007 Chevy Equinox Engine Sputter
40,168 MILES • 6 CYL • FWD • AUTOMATIC
JOHNNYTHROWBACK
  • 6 POSTS
2 months ago, at 37743 miles, I encountered a problem with the engine sputtering when accelerating through 45-50 MPH. It happended at other speeds as well and it seemed to be related to accelerator position. Fuel injector cleaning did not fix this, so I took the car to the dealer. He reported that all of the spark plugs had encountered some misfiring, but one in particular had misfired over a thousand times. He removed this spark plug and showed it to me, and sure enough it was black and had actually cracked. Not wanting to have to return to the garage any time soon, I agreed to have all of the spark plugs replaced.
Now, two months and less than 3000 miles later, the same problem is starting to happen again. Replacing spark plugs appears to have been a band aid on a gaping wound at this point, but it almost certainly will need to be done again before long.
I would like to get an idea of A) what is really the cause of this problem and B) how difficult a DIY repair will be, as I'm not interested in giving the garage any more money at this point.
Thanks in advance,
John
Feb 13, 2010 at 3:18 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds as though it may have a bad/weak coil on that cylinder.I would check spark quality with a spark tester, should be bright blue, if it is orange or weak, replace the coil and the plug for that cylinder again
Mar 5, 2010 at 4:49 AM
JOHNNYTHROWBACK
  • 6 POSTS
[quote:62aacc9523="2CarPros Jack"]Sounds as though it may have a bad/weak coil on that cylinder.I would check spark quality with a spark tester, should be bright blue, if it is orange or weak, replace the coil and the plug for that cylinder again[/quote:62aacc9523]
I did exactly this (actually replaced all spark plugs to be safe), and also inspected and cleaned the MAF sensor, but the sputter still persists. Any other suggestions? Because this is happening during the shift on acceleration to highway speed, is there any chance this could be a transmission issue?
Apr 4, 2010 at 12:42 AM
2CARPRO JACK
  • 11,533 POSTS
You have bright blue spark on that cylinder?i t may not be trans related if it had a plug go bad in that same cylinder before.Ignition misfires usually occur under load. Any chance it is a vibration and not a misfire?
Apr 4, 2010 at 2:15 AM
JOHNNYTHROWBACK
  • 6 POSTS
Well I broke down and took the car to the dealer. It turns out that the tech there used to work on Saturns and recognized the problem as a "sticky" valve that has apparently been a problem in the Saturn Vue among others. It will probably take the rest of the week to get the right parts in and ensure that the problem is fixed for good, but the great news is that it's all covered under the powertrain warranty.
Thanks for your help!
Apr 13, 2010 at 10:38 PM
SWPARK86
Hello.
My Father has recently had this exact same problem with his 2007 Equinox. He bought it new, it now has 90,000 km (55,924 miles), and it also jerks/sputters/stutters when accelerating past 80km/h or 50mph. He has already gone to the dealer and their diagnosis was, like yourself, that a couple of cylinders were misfiring (which seems to be a common problem around the internet for these vehicles). The diagnosis alone cost about $100-150 and they wanted $850 (CAD) for replacement of the spark plugs, ignition wires, and cleaning of the fuel injector (ridiculous).
Naturally, he decided not to take the dealer's asking price for repair and took his car to the garage he frequents and got the spark plugs replaced. The day after, the same problem surfaced again.
After further research on the internet, it seems like the likely cause is the ignition wires and arcing that can occur between spark plugs. Who knows really. That being said, he has decided to return to the garage tomorrow and get the ignition wires replaced.
Regardless, it seems like you went through the same process and 'band aid' fix and it still had problems a couple of months later which is a little disconcerting. If you would be so kind, could you perhaps tell us if the 'sticky' valve solution truly fixes the problem later in the week? My Father would appreciate it greatly and in retrospect, myself as well, as our family will be taking our annual 1500km road trip to east coast for fishing and this would really be a hamper to our vacation. Not to mention if a car problem were to happen this year, it would be a second time in as little as three years that the family car broke down while driving to our fishing spot (this time, it would our new car as the previous car's transmission died completely and we had to purchase the Equinox out of desperation...crazy story really).
$850...sad.
Apr 16, 2010 at 2:38 PM
JOHNNYTHROWBACK
  • 6 POSTS
[quote:0dd4140a68="swpark86"]Hello.
$850...sad.[/quote:0dd4140a68]
Yes, I will be happy to do so. It has been 4 days so I will probably speak to the service department again today.
Apr 16, 2010 at 11:45 PM
JOHNNYTHROWBACK
  • 6 POSTS
[quote:2156de0084="swpark86"]Hello.
$850...sad.[/quote:2156de0084]
Just an update, the dealer is in the process of replacing the valve and 2 cylinder heads, and I should have the car back at the end of the week. We shall see whether this fixes the problem for good.
Apr 21, 2010 at 5:49 AM
SWPARK86
Thank you for the update.
My Father's car is working perfectly after replacement of the spark plugs and ignition wires for the past few days so far. Hopefully, it won't crap out.
Thanks again.
Apr 21, 2010 at 7:32 AM
JOHNNYTHROWBACK
  • 6 POSTS
Well, the good news is that the technician at the dealer was able to identify the sticky exhaust valve, replace it and the related cylinder heads, and over $3000 of repairs were covered under the powertrain warranty. The tech told me that they needed to perform a running compression test, which was new to him, and in this way they identified the cylinder / valve where the compression was well below normal operating range.
The bad news is that my wife called me to report that on her way up to highway speed this morning, there was continued sputter (although not as bad as before). So it's back to the dealer again.
Apr 26, 2010 at 1:28 AM
