2007 Chevy Equinox cruise control
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUREJIM
My cruise control stopped working.
The light on the indicator comes on but when you try and set it doesn't work.
The mechanical said it could be electrical and would cost $800 to fix.
I've only used it 10-15 times for long trips.
How is this possible and is there anything else I can do?
May 28, 2009 at 1:20 AM
RANDYNOX
I have the same problem with mine, but I found that when I rock the lever back and forth, the cruise control starts to work again. You might want to just rock the lever back and forth and see if it helps.
Dec 5, 2009 at 11:16 AM
