2007 Chevy Equinox
ARN243
2007 Chevy Equinox
My key for ignition does not always want to come out and is progressively getting worse. Is this a key problem or a ignition problem
Oct 15, 2010 at 6:15 AM
GMTECH
  • 537 POSTS
What you should check is your key. See how worn down it is. If it is quite worn start by replacing it. Second the cylinder is causing the key to wear abnormally fast. The cylinder should come out and be lubricated along with the housing. After that you should be in much better shape.
Jul 31, 2018 at 11:45 AM
