2006 Chevy Equinox PVC Valves
50,000 MILES • 6 CYL • AWD • AUTOMATIC
CMFH
One chevy mechanic told me that the pvc valve was oiled soaked and needed to be replaced. He said the part number is 12575301 and would cost 21.11 + Tax. I moved and no longer had easy access to that dealership so I took the car to another dealer closer to my home. The Mechanic at this dealership said that the valve could not be replaced by itself, that I would have to replace the pvc and the hose assembly that comes in one unit with frt valve cover. this part would cost 178.00. Which of these is correct?
Aug 26, 2008 at 11:09 AM
BRIAN 1
  • 1,030 POSTS
the person that told you the pcv is part of the valve cover.that is the only way you can get these.
Aug 26, 2008 at 11:44 AM
