2006 Chevy Equinox Key lock
56,000 MILES • 6 CYL • AWD • AUTOMATIC
BODUSHE
I have a 2006 chevy equinox. The problem i have been having is when i go to stick the key in, it wont turn, its like it is stuck not sure what is wrong or what part i need to get to replace this problem, just wondering if you could help me out?
Aug 4, 2010 at 2:21 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.I want you to look at your key is it all worn down?If it is do you have a spare key that isn't all worn if so try that key.If the key is all worn down and you don't have a spare that isn't.I want you to go to the dealer and have a fresh key cut from your key code.Don't have the old worn down key copied all you will end up with is a copy of that old worn down.Let me know what you come up with.
Aug 4, 2010 at 3:54 AM
BODUSHE
I have no spare key and im located in guam so its kinda of hard to go to a dealership and get a key redone.
Aug 4, 2010 at 6:38 AM
SATURNTECH9
  • 30,869 POSTS
That's understandable i was just suggesting that your key could be worn causing your cylinder not to turn.That's the first thing i look into before selling someone a new ignition cylinder and key.So is your key worn down a lot?If it doesn't look that worn we can try the next step.Remove the ignition cylinder bezel then tap lightly on the cylinder with a hammer then see if it turn's Try that a few time's and let me know if it turn's.It's stuck in the lock position correct?
Aug 4, 2010 at 8:21 AM
BODUSHE
Well i wont be able to that just yet sir. Currently deployed and my friend that is watching my car will not be able to do that because he doesnt want to screw my car up.
Aug 4, 2010 at 9:22 PM
SATURNTECH9
  • 30,869 POSTS
Alright that's our first step if we can get the cylinder to turn it will be a lot cheaper and easier to fix.Let me know when you try it and i will be here to tell you what to do next.
Aug 5, 2010 at 4:21 AM
