2006 Chevy Equinox compressor
94,000 MILES • 6 CYL • FWD • AUTOMATIC
TONY TAYLOR
I find no low pressure switch to jump the compressor
to add freon. Can the jump start on this model be done manually or does this have to be done at a dealer through the computer
Oct 13, 2010 at 5:11 AM
WRENCHTECH
  • 20,760 POSTS
There's nothing that needs to be jumped, even if it did have a low pressure switch. The compressor would engage as soon as a small amount of refrigerant was in the system. If the system is empty you shouldn't be just adding to it anyway. You have to evacuate all the air out first.
Oct 13, 2010 at 7:42 AM
