2006 Chevy Equinox
59,000 MILES • 6 CYL • AWD • AUTOMATIC
CHERYLZ
key pad does not open drivers door, it opens and locks all other doors, key pad will not lock drivers door
Oct 26, 2010 at 1:32 PM
GMTECH
  • 537 POSTS
It is quite possible that you might have a wiring problem with your vehicle. You need to check the wiring in the boot from the body to the door. I have seen the equinox with broken wires causing a similar problem
Oct 29, 2010 at 7:11 PM
