ALANHOLUB
disconnected battery.reconnect battery, no start, key stuck in ignition.
Feb 25, 2014 at 11:05 AM
  • 110,248 POSTS
Is the battery good and fully charged? Have you checked main fuses under the hood? Does the dash light up?
Try the relearn procedure below
https://www.2carpros.com/articles/how-to-reset-a-security-system
Feb 25, 2014 at 9:24 PM
MLENNI
  • 6 POSTS
When I started the car today the radio would not turn on at all, but the car started so we disconnected the battery and reconnected and the key got stuck! The radio, lights, everything worked, but the windows and locks did not work and car would not turn over at all. I am not sure what to do or where to start.
Mar 19, 2019 at 12:06 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
The key was not on when you disconnected the battery and hooked it back up? Did you try to jump start it? Also, has the battery been charged and tested? Are the battery cables clean and tight?
MLENNI
  • 6 POSTS
Battery was charged overnight. Key was not on and we tried to jump start it last night.
SATURNTECH9
  • 30,869 POSTS
Does the engine crank normally and not start?Also the security light isn't on solid or flashing with the key in the run position?
SATURNTECH9
  • 30,869 POSTS
Also why was the battery disconnected to begin with?
BSMENZ
car wouldn't start, removed battery to have tested, battery charged, and reinstalled, still wont start and now key will not release from ingnition
HMAC300
  • 48,601 POSTS
reset security system if no manual look online. disconnecting battery engages it.
MLENNI
  • 6 POSTS
The radio wouldn't work so we disconnected the battery. The car won't turn over at all and the screen reads service vehicle soon. There's no security light on. Windows and locks don't work either
MLENNI
  • 6 POSTS
And the key is stuck in the ignition
SATURNTECH9
  • 30,869 POSTS
You should have tried pulling all the radio fuses for ten minutes that's what your supposed to try I know you didn't know have you checked all the fuses yet?
MLENNI
  • 6 POSTS
We we tested all of them they are all good and the relays are good too
CHINADOLL84
My car will not start, I got a double jump last night and made it home but once I arrived there and turned my car off, that was it. I tried to restart it and nothing at all, all the lights and radio and everything are coming on but it like there is no juice. I also have an electrical issue with my high beam lights but I don't see that making my car not start, plus I am able to unplug the high beams therefore its not draining. My boyfriend works on cars and before I turned it off it was making an awful awful sound and it says it sounds like the inside of the alternator is tore up and needs to be replaced. I am just curious what it could be that is causing this issue?
  • 110,248 POSTS
The noise could be the alternator or a belt that is loose. Is it a screaching sound? Is the battery light staying on when the engine is running?
  • 55,627 POSTS
It really sounds like the battery is having a problem. Can you test it by following this guide please.
Please let us know what happens so it will help others
Best, Ken
CHINADOLL84
The battery light is not coming on at all and we got the starter checked and its not the starter either. It's been a few days and the lights and things are still coming on. My boyfriend even tried his brand new battery... And still nothing at all.....
MLENNI
  • 6 POSTS
Thank you for your reply. We tested battery it's still good. Car reads Service vehicle soon, service air bags soon, service tire monitor system soon. Maybe body control module?
  • 110,248 POSTS
First, sorry for taking so long to get back with you. It's that time of the year. Anyway, the starter could check good even if it isn't. What needs to be done is the following:
When it doesn't start:
Have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should have 12v when it is in the start position. If you do, replace the starter. If you don't, check the starter relay under the hood in the relay box (power distribution box.
Let me know what you find.
STEVE W.
  • 15,389 POSTS
Try this. Disconnect the battery. Connect the two battery cables together to drain the capacitors in the system and clear any learned behavior. Reconnect the cables and see if anything has changed.
TACOBB
When starting the car, everything on the dash lights up, but then goes dim. It took getting a jump to get the car to start. I am not sure if it is the battery or the electrical system. Once I got the car home I turned the car off, and tried to restart it and it did the exact same thing. It took another jump to start the car. I don't know what it could be.
  • 110,248 POSTS
It could be a bad battery or just a corroded battery terminal. Check the terminals to make sure they are clean and tight. If they are, have the battery load tested at a parts store. They will do it for free.
Mar 19, 2019 at 12:07 PM (Merged)
FRITZR
Parked Equinox was bumped from behind. No damage except a scratch, however the anti theft light is now on and the car won't start. I tried looking up information about a possible fuel shut off switch being triggered but found nothing. Any help would be greatly appreciated to avoid a tow to the dealership. Thanks
HMAC300
  • 48,601 POSTS
this should be in your manual on how to reset but try what im sending in pic.
BULLETPROOF86
lights come on. wont make a sound when i turn the key. never had a starter problem before
SATURNTECH9
  • 30,869 POSTS
Is the security light on solid or flashing?Have you had the battery tested?Made sure the battery cables are clean and tight?
FIXITMR
  • 9,989 POSTS
try it in neutral instead of park.
GILES
Other Category problem
2005 Chevy Equinox Engine Size unknown All Wheel Drive Automatic 71000 miles
changed the blower motor for heater and now the car will not start. Won't even turn over. The head lights work when the key is on but won't turn over. put in a new ignition relay. What else could it be?
DENNYP
  • 1,824 POSTS
Is the security light flashing?
GILES
No it is not flashing.
DENNYP
  • 1,824 POSTS
you need to make sure you are getting 12 volts power to the starter solenoid. If you are getting the voltage, then the starter is bad. If not, let me know.
PSURIDER
Electrical problem
2005 Chevy Equinox All Wheel Drive 76500 miles
I saw a post recently with the same problem. I hadn't been driving my Equinox regularly for a couple weeks because I have received a company car. One day the Equinox would not start. I assumed it was the battery. It went to the garage and the problem was not the starter or the battery. $550 later they had found a broken wire. It started up and all seemed fine. One week later I took it on a 2 hr road trip. After sitting for a couple hours it again would not start. There is power to the radio and windows but it won't even turn over.
DENNYP
  • 1,824 POSTS
sounds like an issue with the security system. Have it scanned for codes at the dealer. It will probably need the passlock sensor.
COURTELLIS
The car does not start and all the power is working, sound like a starter issue, but this care is so strange can,t tell. I thought it was the altenator until the power came on. It will click once when ever I try to start, so it sounds like a silinod? is gone bad.
  • 110,248 POSTS
First, is the vehicle still under warranty (3 year / 36K). Second, here is what I need you to do. If the starter isn't working, have a helper turn the key to the start position while you check for power to the smaller wire on the starter. You should be getting 12+ volts.
