2005 Chevy Equinox Whining noise in wheel in front right pa
2005 CHEVROLET EQUINOX
36,350 MILES • 6 CYL • AWD • AUTOMATIC
LYNN ANDERSON
I just had my car checked out and was told that the whining was caused by a "center support bearing". I had it greased and was told he could last a week or 2 yrs.
Can you tell me where it is located on the car and if this needs to be replaced a some pioint.
Feb 11, 2009 at 7:00 PM
EFICHTENMAYER
  • 7 POSTS
Was wondering if you have figured this out yet? I am having a similar issue.
May 5, 2009 at 12:31 AM
LYNN ANDERSON
The Chevy Dealer said it was the center support bearing. It can be greased or replaced. To replace it is at $800. I chose to have it greased. they said it could last 1 day or several years. However, they did not grease, they used oil. I have a personal mechanic that inserted grease with a small tool. The whining has stopped.
I believe I will continue to have it greased.
May 5, 2009 at 7:51 AM
