Does this car HAVE a steering wheel locking mechanism so the wheel will not turn with the key out?
Jan 11, 2010 at 5:51 AM
BRIAN 1
✓Experienced Mechanic
The steering wheel lock is controlled by the ignition switch. Here are diagrams to help you change the ignition lock out and so you can see how the lock works. There is a small rectangle metal pin that pushes outward to lock the steering wheel.
Thanks you this worked perfect I cant believe this site is free! Thanks :)
Jan 11, 2010 at 7:45 AM
BRIAN 1
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers
Jan 11, 2010 at 9:19 AM
