2005 Chevy Equinox Left blinker light stays on steady
SEAN1969
Electrical problem
2005 Chevy Equinox 6 cyl Two Wheel Drive Automatic
The left blinker signal on my wife's dashboard stays on steady even when it is not chosen or she puts the blinker on to turn right. The turn signal bulbs on the outside of the car seem to be brighter than the daytime running lights. It seems to be that the turn signal is stuck in the on mode but not blinking. I did check fuses and swap bulbs out to no avail.
Jan 18, 2010 at 3:03 AM
KHLOW2008
  • 41,812 POSTS
Hi sean1969,
Thank you for the donation.
The problem is most likely to be caused by a bad ground circuit or crossed wires. For the bulb that is brighter, check the ground connectiosn the area and clean retighten to test.
Jan 18, 2010 at 9:32 AM
