Ignition Cylinder Replacement
56,000 MILES • V8 • AWD • AUTOMATIC
EQUINOX1992
I recently had my ignition cylinder replaced at the dealership. I was given one key after the work. I noticed later that my door lock was not replaced to match the new key. The work was covered under my warranty.
Should I have expected to receive two keys and to have the door lock replaced to coincide with the new ingnition key?
Nov 19, 2009 at 4:53 PM
SQM
  • 6,383 POSTS
Yes, a proper repair/replacement procedure will include all the lock cylinders so you don't have to have several keys just to get in and start. Many times dealerships gets the cylinders rekeyed to match one key.
Jul 15, 2021 at 1:19 PM
