2005 Chevy Equinox Heater blows cold
52,000 MILES • 6 CYL • FWD • AUTOMATIC
TOMMYJOHNWRIGHT
I had the thermost replaced..heater lines that run into the firewall are hot..The box where the heater core is located is warm..The vehicle only blows cold air.Do I have some type of electrical or sensor problem.
Feb 1, 2009 at 12:58 PM
DOCFIXIT
  • 18,828 POSTS
A blend door motor not operating. I believe it is behind glove box. You'lll see a rod operate from cold to hot see if it turns.
Feb 2, 2009 at 12:51 AM
