2005 Chevy Equinox EVAP System error during none purge cond
123,000 MILES • 6 CYL • FWD • AUTOMATIC
HMIKERICH
Im getting and P0496 check engine code on a 05 chevy equinox i replace the gas cap last time it did this and it went a way. So i did the same them and everytime i earse the code about a week later the light come back on with the same code. What could be the problem?
Apr 20, 2009 at 5:05 AM
  • 110,248 POSTS
You have a EVAP code for a small leak. It could be the cap, but rarely do they go bad. What I suggest is this. Take the car to the shop and have the "Fog" the system. What they will do is actually pressurize (like 1 PSI) the evap system with a fog. Where the leak is, the fog will leak out. That is the easiest way to find it. Otherwise, you could be looking for a year and still not find it.
Let me know if it helps.
Dec 15, 2009 at 5:35 AM
