1987 Chevy El Camino Tachometer
DON ERNST
Electrical problem
1987 Chevy El Camino V8 Two Wheel Drive Automatic
My tach has 3 studs in the back that plug into 3 clips. What feeds each clip and what are the readings supposed to be for each. My tach goes all over,back and forth from o to max when running or just cranking. Any ideas?
Thanks, Don
Apr 11, 2010 at 1:33 AM
HMAC300
  • 48,601 POSTS
one might be a 12 volt supply one may be ground and another would be the tach going to the coil or where its 'pick up is. You probably have a bad tach.
Apr 15, 2010 at 9:36 AM
