1987 Chevy El Camino fuel pump and relay
1987 CHEVROLET EL CAMINO
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
PUNCHO114
I just replaced the fuel pump. The car still will not start. If I put gas in the throttle body it does start. So, is there any other areas I should be looking at to see why gas is not getting to the throttle body?
Mar 15, 2009 at 9:47 AM
Check the fuel pressure and also for injection pulses.
Mar 15, 2009 at 10:02 AM
PURESPL
Is it original motor? If it is should have carburetor not throttle body. check and make sure the rod on your motor is pushing the lever of fuel pump. Also check fuel filter.
Mar 16, 2009 at 3:41 PM
