1986 Chevy El Camino Fuel pump
1986 CHEVROLET EL CAMINO
200,000 MILES • V8 • 2WD • AUTOMATIC
86ELKY
This is kind of a project car that I've been working on and I had it running until today. I was installing a floor shifter so I was underneath the car a lot putting in brackets and running cables and such. When I was done the car wouldn't start. And no its not the neutral start I tied up the mechanism. The starter goes and I could always hear the fuel pump come on when I started it but now I can't hear it anymore. Any idea what I might have done to kill the fuel pump?
Nov 22, 2009 at 8:19 AM
Power the gray wire on the fuel pump connector directly from the battey if it comes on-check fuel pump fuse and FP relay if it doesn't come on verify that the ground wire is good on the pump
Nov 22, 2009 at 8:23 AM
