1986 Chevy El Camino carburetor
54,633 MILES • V8 • 2WD • AUTOMATIC
MR211SMITH
The car has been sitting for three years. I recently purchased the car and I found out the car runs good but floods after about fifteen minutes. I replace the quadrojet carb with an edelbrock 600, installed every adaptor that was needed. NOW! the car starts but stays running only with my foot on the gas? What have I done wrong?
new spark plugs, wires, filters and battery so far
Apr 2, 2010 at 5:16 PM
  • 75,988 POSTS
Did you adjust the air/fuel mixture and idle screw properly If so check the EGR valve could be cracked open causing it not to idle
Apr 2, 2010 at 11:55 PM
