1986 Chevy El Camino
78,000 MILES • V8 • 2WD • AUTOMATIC
SCOTT DOYLE
When my car sits for a month or two, I lose 1 to 2 quarts of trans fluid. If I drive the car at least once a month, nothing leaks out. I have wiped everything down and can't find a repairable leak. Where is it coming from? My Corvette does this also.
May 3, 2009 at 1:15 PM
HMAC300
  • 48,601 POSTS
a leak like that can come from several places. The dipstick tube O-ring, the pan gasket, the oil pump bolts gaskets, the oil pump O ring or the cooling lines. I'd check the lines first.
Oct 6, 2009 at 6:48 AM
