1977 Chevy El Camino Transmission
1977 CHEVROLET EL CAMINO
LARRY 16
Transmission problem
1977 Chevy El Camino V8 Two Wheel Drive Automatic
Is it possible if you change the ignition in the sterring colum that could make the car not go into drive?
Thank you
Jan 6, 2010 at 2:48 PM
HMAC300
  • 48,601 POSTS
if your car shifts to all gears then no. Check your trans fluid level, then try all the gears if you have one gear then the trans is probably in need of rebuilding. Take it to a pro and have him check it out.
Jan 10, 2010 at 7:45 AM
