1985 Chevy El Camino starting car
1985 CHEVROLET EL CAMINO
999,999 MILES • V12 • 2WD • AUTOMATIC
ALEXISSHADY1
car will not turn over. i get nothing not even clicking,
battery is new. lights, blinkers, and all electrical works.
what can it be?
Jun 3, 2009 at 5:03 AM
MIKE H R
  • 3,094 POSTS
start at the battery and clean the connections. Even though they seem good sometimes they can be making little contact. Follow the wire to the to the starter to make sure you have voltage at the starter solenoid. {the bigger wire} then check the wire that goeas on the s terminal on the solenoid. Most times this is where the problem will be. most times they are secured with a small nut. This wire does become frayed from vibrations and will break inside the shielding. clean and replace this wire .
Jun 3, 2009 at 9:21 AM
