1982 Chevy El Camino testing a brake master cylinder
1982 CHEVROLET EL CAMINO
OLDCAR1951
Brakes problem
1982 Chevy El Camino 6 cyl Two Wheel Drive Automatic
200,000
When the brake is depressed on a two-reservoir brake master cylinder, is it normal for a small geyser to appear in one, both or neither reservoir? What should be seen in each reservoir when the pedal is depressed?
Thanks,
Rick
Nov 16, 2009 at 5:39 AM
HMAC300
  • 48,601 POSTS
basically just fluid should be seen in resevoir. I've seen that happen many times what you describe wth nothing wrong. YOu can only push so much fluid through the orfices and the rest will need to go back to the resevoir. Now if your brake pedal ges to the floor and then wil pump back up that is th indication of a bad master cylinder....
Jan 10, 2010 at 7:56 AM
