1981 Chevy El Camino
99,999 MILES • 6 CYL • 2WD • AUTOMATIC
GARAGEMEKANIK613
  • 5 POSTS
If a car has been siiting for a very long time (15 or more years) what are the chances of the computer being no go anymore when attempting to get the car going again?
Mar 6, 2010 at 7:12 AM
  • 75,988 POSTS
You need to do below to determine what's causing it not to start this is your starting point:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Mar 6, 2010 at 7:39 AM
