1980 Chevy El Camino What is Going on ???
80,000 MILES • V8 • 2WD • AUTOMATIC
CRMIKEY
I have a 1980 Chevy El Camino 350 Engine I tried to start the car the other day And nothing cleaned and checked the battery and still nothing ... I had the car towed back to house and wouldn't you know it everything is OK ... it started right up ...
Hummm
What is going on ??? Mike
Dec 29, 2008 at 7:10 AM
  • 31,937 POSTS
Hi there,
I would start with the simple things, check that the battery terminals are all clean and tight, check the terminal connections at the starter motor for a good contact and no corrosion, start here,
mark (mhpautos)
Dec 29, 2008 at 7:24 AM
BOWTIE BABY
  • 101 POSTS
I had a simalar problem 1 time, It was the small wire that comes off of the battery cable terminal on the starter solenoid. Its what feeds power to the fuse box. Check and or replace a foot or two of that wire with a comperable size wire, I beleive it is 10 guage.
Feb 5, 2009 at 7:47 PM
