i install front seal on transmision,but it is still leaking what can be wrong?
Nov 8, 2008 at 1:27 AM
MIKE H R
MEMBER
did you check the pilot shaft bearing to see if there was any play in it? With the bearing bad or goinfg bad it lets the shaft move around insyead of holding it perfectly straight.
Dec 20, 2008 at 3:48 PM
