Electrical problem
1978 Chevy El Camino V8 Two Wheel Drive Automatic
The original turn signal arm is still wired in, and the turn signals still work. They are just not attached. How do I remove the steering wheel, (got that), and then remove the steering lock and ignition to eithir repair or replace the arm to activate the turn signals, high beams and cruise?
Oct 18, 2009 at 9:47 AM
