1978 Chevy El Camino lights
180,113 MILES • V8 • 2WD • AUTOMATIC
BOBSGIR62
My headlights flash on and off and the inside lights also flash but when I put on the break at a stop they get bright and and don't flash.Lights flash on and off only when driving.
May 7, 2009 at 11:40 AM
HMAC300
  • 48,601 POSTS
if your headlights are flashing off and on the circuit breaker in the switch is kicking on and off. Check the dimmer switch on the floor, after years of water and crud they stick and are often the cause of this. Otherwise it could be a turn signal bulb that has shorted out and is causing this. A good way to check is put your brakes on and see if any turn signal bulbs light up in front. If they do, then your problem is in the rear bulbs.
Oct 6, 2009 at 6:59 AM
