1978 Chevy El Camino Ignition (no crank)
1978 CHEVROLET EL CAMINO
68,000 MILES • V8 • 2WD • AUTOMATIC
EL MONSTERO
New starter, new battery, new battery wires.
The car suddenly stopped sarting, no click, no sound or action from turning the key. How do you remove the ignition switch, & how do you remove the netraul saftey switch? These are the only thing left that I can eliminate in the ignition loop? Besides the wire that runs to the fuse block wich I will also replace, alt has worked fine before this no start problem.
Nov 27, 2008 at 8:16 AM
MIKE H R
  • 3,094 POSTS
you say that the starter wa new what about the starter soloind. try jump starting it. that would definatly elliminate the starter if it starts.
Dec 20, 2008 at 3:51 PM
