1978 Chevy El Camino Charging System on 78 Elcamino
JSHD41
Electrical problem
1978 Chevy El Camino V8 Two Wheel Drive Automatic
I Have A 78 Elcamino and when you turn on the headlights, heater, wipers and then the volts meter goes down into the red. If you Have everything off it charges fine anyone have any ideas. I Have put a new Battery and alternator.
Jul 29, 2009 at 8:08 AM
  • 75,988 POSTS
Double check wiring
There's a D-hole on back of the alternator ground the tap and see if the voltage increases if so the voltage regulator is defective if not the alternator
Jul 29, 2009 at 8:23 AM
