1973 Chevy El Camino
1973 CHEVROLET EL CAMINO
99,000 MILES • V8 • 2WD • AUTOMATIC
ELCAMINO
how to test point and condenser
Dec 13, 2008 at 1:05 AM
HMAC300
  • 48,601 POSTS
I don't ever remember testing points or condensors. And i've been doing ths for a very long time. If the points are burnt-replace them and the condensor. If you have a dwell meter make sure to set them at 30 degrees with the vacuum disconnected. Then set your timing the same way. Best thing to do though is get rid of them and either put in a petronics electronic ignition or put an electronic distributor from a later model Chevrolet. thoseare much better than points and you don't need to "change them" every time they go bad.
Dec 16, 2009 at 9:33 AM
