1972 Chevy El Camino Engine won't shut off
1972 CHEVROLET EL CAMINO
72 CHEVY
1972 Chevy El Camino V8
We have a 72 El Camino, turns on just fine and stays on. But, when it comes to turning it off, we can't. Even if we lock the ignition and remove the key. We thought it was the ignition switch and replaced it. But, it only fixed the problem temporarily. We are once again having problems shutting the car off.
Apr 13, 2010 at 11:10 AM
Hi 72 chevy, Welcome to 2carpros and TY for the donation
Check if the primary ignition circuit wire is shorted to the power input on the ignition switch wiring if not could also be the idle speed is too high and the throttle plate is not closed completely causing it to run-on/diesel
Apr 13, 2010 at 11:35 AM
