1970 Chevy El Camino cruise control
105,000 MILES • V8 • 2WD • AUTOMATIC
1970ELCO
Hello, I'm removing my cruise control unit. Is the accumulator needed? Can I remove it? It seems to be a vacuum device that has a hose going to manifold and service device.
Jan 21, 2010 at 3:35 PM
HMAC300
  • 48,601 POSTS
if you are removing the unit then taek the accumalator off as well. Just be careful not to screw anything up and don't cut the wires or plugs. Tape them back out of the way in the harness. Make sure to plug the vacuum line to not screw up the running of the engine..
Jan 30, 2010 at 7:56 AM
