1990 Chevy Custom Deluxe
1990 CHEVROLET CUSTOM DELUXE
300,000 MILES • V8 • 4WD • MANUAL
DRYWALL1974
1990 chevy , lean condition no the throttle , backfiring in the manifolds .Ran fine any deeper than quarter into the pedal backfire in manifolds .Ran like that from Butte Mt to Ca. then quit . Spark no fuel .Rookie move ; relaced fuel pump and relay for pump ALL fuses are good . No power to fuel pump fuse ?
Nov 24, 2009 at 1:17 PM
MICKEY-D
  • 304 POSTS
You are a little short of info here. Does it have a throttle body set up, port injectors, it all makes a difference. will it run if you give it a sniff of starting fluid? If so, check for power at the injectors or throttle body with key on, and while cranking the engine.Could also be a bad fuel pressure regulator. Check the fuel block for fuel, and pressure. Good luck.
mickey-d
Dec 3, 2009 at 11:23 AM
