1982 Chevy Custom Deluxe Fuel
DAVE40
  • 5 POSTS
Engine Mechanical problem
1982 Chevy Custom Deluxe V8 Four Wheel Drive Automatic
I have a 305 motor that has been running fine up until yesterday. It wont stay running. When i get it started and try keeping it running, it blows smoke white smoke out of the exhaust and the starts popping and the wants to die. I made sure it was getting fuel, I checked the oil dipstick to make sure there was no water in the oil. I canno tlocate the fuel filter to check that. Can this be a fuel filter problem or (I hope not) a head gasket?
Oct 12, 2010 at 6:00 AM
WRENCHTECH
  • 20,760 POSTS
White smoke means coolant is being burned which points right to a blown head gasket.
It's possible for a bad intake manifold gasket to do that too but that engine is not known for that.
Oct 12, 2010 at 6:19 AM
DAVE40
  • 5 POSTS
Thank you for your reponse. You mention that it could be intake gasket problems. I have a slight oil leak coming from the gaskets for the valve covers that leak near the gasket for the intake. I wonder if this could be destroyng the gasket for the intake.
Oct 12, 2010 at 6:55 AM
WRENCHTECH
  • 20,760 POSTS
No, that's not related
Oct 12, 2010 at 6:57 AM
