turn signals
ZNIRPP
I have recently purchased a 2001 Chevrolet Corvette Convertible, with 42365 miles and a LT350 engine w/ auto. trans., and have had rapidly flashing rear turn signals, with no front signals at all; and then no back turn signals [or front] either. Before all this happened, a front turn signal bulb was replaced by a Chevrolet dealership. Do you know what the problem could be?
Jun 29, 2007 at 8:44 PM
STRAIGHT AHEAD
  • 41 POSTS
ABSOLUTELY! But have them check the signal flasher unit also. Which should be located in the fuse box or under the dash. The wrong bulb may have cause the system to malfuction. Good luck
Jul 21, 2007 at 5:09 PM
