1974 Chevrolet Corvette Stuck Key
CPAVETTE
I recently purchased a 1974 Vette that had sat for 25 years without being run. The ignition key was stuck when I purchased it. I have gotten it running and now would like to get the key out. The ignition will turn to start the car but will not turn back far enough to allow the key to be removed. It is a 4 speed manual, 350 with 65,000 miles.
Also, the 4 speed will not go into reverse.
Any ideas for either issue?
Oct 18, 2007 at 6:49 AM
2CARPRO JACK
  • 11,533 POSTS
No reverse is probably a shifter bushing gone bad, look on shift arms on side of trans.To get the tumbler out the steering wheel has to come off, on those Vettes with the telescoping wheel it can be a pain, might want to have a shop with the right tools do that for you.
Oct 18, 2007 at 7:22 AM
Suggested Repair
For no reverse, inspect the shifter bushings on the shift arms at the side of the transmission. To remove the stuck ignition key, the steering wheel must come off so the tumbler can be removed; on a telescoping Corvette wheel this is difficult, so a shop with the proper tools is recommended.
Conversation Summary
The owner of a 1974 Chevrolet Corvette that sat unused for 25 years says the ignition turns to start but will not turn back far enough to release the key, and the 4-speed will not go into reverse. The expert says missing reverse is likely a bad shifter bushing on the transmission shift arms, and that removing the ignition tumbler requires pulling the steering wheel, which is difficult on telescoping wheels and may be best left to a shop.
