I have a 1992 Chevrolet Corvette with a 350 engine. It is hard to start, it will just keep turning over until you give it gas. It seems to start up easier when the engine is hot, for instance If I stop and run in a store real quick and come back out to crank it, it will start right up. It will also sometimes when I go to crank it, the engine will rev up really high and the only way to stop it I have to put it in drive to slow the engine from reving up so high. I had the car tuned up and all sensors are good. I have not had the starter checked yet could that be the problem? Thank You, D Ruefle
May 25, 2007 at 3:06 PM
