right sde turn signal not working
MWALTON
1975 corvette, 80,000 miles, 350ci
The left turn signals work.
I replaced the front and rear bulbs for the right side turn signals. They light up, but still did not blink. I then replaced the flasher unit on the fuse panel. The left side signals work. Strangely enough, the left side worked when the flasher unit was not in. Does the round flasher unit control the turn signals or the emergency flasher system?
Do I have a wiring problem or is it possible the turn signal switch that is located in the steering column have something to do with it?
Mike
Oct 24, 2007 at 11:54 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e86c7dc37a="mwalton"]1975 corvette, 80,000 miles, 350ci
Mike[/quote:e86c7dc37a]
Try to wiggle and jiggle the switch and notice
if change happen ( yes)
The switch no good
or try to pull the 4 way and see if all working
If they do
wiring ok
If still no
.you may have wiring prob
Good luck
Oct 24, 2007 at 12:23 PM
