No Limate controls or radio
RICK1990
I have a 1990 vette, 350 automatic, last week, the radio sent out, the power was still their, but the buttons didn't light up. then, the next day, the climate control stopped working. When you hit a pot whole, everything works, for 20 minutes, then I get my 3 --- on the climate control and no buttons are lit up, the same with the radio.. I check all the wiring harnesses under the radio, steering column and glove box, can't seem to locate my problem.
i did find a ground screw on the firewall under my steering column, but i couldn't find a wire anywhere near it.. I'm stumped.. Anybody have any thoughts?
Thanks.
rich
Apr 21, 2007 at 10:53 AM
STRAIGHT AHEAD
  • 41 POSTS
The 3 on the climate control is a code given by system. The radio sent out for repair? If it was a factory unit. Good because so much electrial on this series of Vettes are married. If you have an after market radio system it will completely mess with your eletronics. The 3 on the display is saying is not getting the correct info. I would system check by a dealer. Or check the connection with the amibent control senor. In the front bumper section. Or referre to dissconection of the battery in the owners manuel. Good luck.
Jul 21, 2007 at 7:47 PM
