corvette auto lock
GARYSTEVENS
my dad has a 1995 corvette. the auto door door lock is made into the ignition key so when you step away with the keys in hand the door automatically locks. sometime the locks do not lock and also the car will not turn over. after a couple trys the car will start and work fine.more often than not it is not working properly. could it be in the security system or the key itself. please help cant figure it out. thanks
Jun 21, 2007 at 12:12 PM
STRAIGHT AHEAD
  • 41 POSTS
Best Guess. The remote needs a new battery. And then you need to clear the anti thief codes. Disconnect the battery for a few minutes to clear the codes. Before you unconnect the battery make sure the windows are down. And the doors unlocked. Have the remote key in the house. When you have the battery reconnected. Bring the keys into the area. It should reset the configuration.
Jul 21, 2007 at 6:44 PM
