Car crank up and cut off
WELTONPEE
  • CHEVROLET CORVETTE
1993 corvette 189,000miles car crank up and cut off, sometime the security light flash on and off I wait a few minute it crank back up sometime I have to wait longer.
Wednesday, July 11th, 2007 AT 3:25 PM
STRAIGHT AHEAD
  • 41 POSTS
Best guess. You need to get a new key made for the car. The key has a chip built into it. Over time they were out. The anti theif is doing it job. But it is not getting the right info. If the car is not getting the right info it will automatically turn off the fuel pump. Also you computer is storing codes. Buy disconneting the battery for a few mintues will help clear some stored error codes. If you dissconnet the battery make sure the doors are unlocked and the windows down. When you have a new key made. It will have to be order or coded at a Chevy dealer. Make sure that it is working properly.
Good luck
Sunday, July 22nd, 2007 AT 12:01 AM
GWH
  • 14 POSTS
If it isn't your key, then when was the last time the fuel filter was changed?
GWH
Friday, August 24th, 2007 AT 4:23 PM
