87 corvette fuel injectors
RODLONG
19 87 corvette 5.7 l tuned port injected with 2000000 miles
my question is this year comes with 2 different injectors the after markets only give one are they compatible with both oem?
Aug 20, 2007 at 4:25 PM
  • 75,988 POSTS
[quote:e3063f8ef9="rodlong"]19 87 corvette 5.7 l tuned port injected with 2000000 miles
my question is this year comes with 2 different injectors the after markets only give one are they compatible with both oem?[/quote:e3063f8ef9]
It came with this part no. 17111961
Aug 20, 2007 at 4:51 PM
RCCCPA
  • 5 POSTS
Have a 1988 just bot, same motor. Went in for fixing up when I got it. Had fuel injector issues, had them clean up & 1 failed. The ones in the car were made by Accel, I called them & got a single replacement to match. The whole set of 8 was pretty reasonable also, but I stuck with just getting one. Check them out, they were real helpful. I can't find the phone number for you. Rich
Nov 1, 2007 at 9:41 AM
