2008 Chevy Corvette IAT/MAP Plugs and/or harness
7,500 MILES • V8 • 2WD • AUTOMATIC
TREBORAUDIO
I just wanted to know if you could tell me or provide me with a diagram or schematic drawing identifying exactly which of five (5) cables that plug into the IAT/MAP or MAF sensors are for the IAT sensor? I know that of the five cables or wires connected to the plug one(1) is a ground, I assume the black one, two are for the MAF sensor and two are for the IAT sensor. I just don't know which are which. If you could help me with this it would be greatlyappreciated. Thanks. By the way I don't have a problem making a donation but I have never used this service before and just wanted to see what type of results I receive.
Sep 12, 2008 at 3:47 AM
BRIAN 1
  • 1,030 POSTS
this is for maf and iat. A
0.35 YE
492
Mass Air Flow (MAF) Sensor Signal
B
0.8 BK/WH
451
Ground
C
0.5 PK
539
Ignition 1 Voltage
D
0.35 TN
2760
Low Reference
E
0.35 TN
472
Intake Air Temperature Sensor Signal
this is for the map sensor with LS3 engine 1
0.5 GY
2704
5V
2
0.5 OG/BK
469
Low Reference
3
0.5 L-GN
432
Manifold Absolute Pressure (MAP) Sensor Signal
this is for the map with LS7 A
0.35 OG/BK
469
Low Reference
B
0.35 L-GN
432
C
0.35 GY
2704
5V1
Sep 12, 2008 at 12:17 PM
