2004 Chevy Corvette HEADLAMP DOORS
2004 CHEVROLET CORVETTE
18,000 MILES • V8 • 2WD • AUTOMATIC
DON KERANS
MY RIGHT HEADLAMP DOOR DOES NOT FLIP UP. IT IS NOT A GEAR PROBLEM, ONCE I WIGGLED THE HARNESS THAT GOES INTO THE TOP OF THE MOTOR AND IT STARTED WORKING FOR A SHORT WHILE. nOW IT DOES NOTHING AGAIN AND I HAVEN'T BEEN AS LUCKY WITH THE MAGIC TOUCH. ANY CLUES?
THANKS , DON
Jul 31, 2009 at 10:54 AM
BRIAN 1
  • 1,030 POSTS
Disconnect the headlamp door control module.
Using a test lamp connected to ground, probe the inoperative headlamp door motor fused battery positive voltage supply circuit.
Turn the ignition to the ON position.
Turn the headlamps ON. if the test lamp doesnt light check for a short to ground on that circuit,if it does light,Test the inoperative headlamp door assembly motor up and down circuits for a short to ground, short to battery positive voltage or an open. if not it could be many things,possible headlamp control module.sounds like a circuit problem,post back with what you find.
Jul 31, 2009 at 12:33 PM
