2004 Chevy Corvette flushing fluids
55,486 MILES • V8 • FWD • AUTOMATIC
DAGRAD
I was wondering at 55,486 miles on my vette, what type of maintenance check ups should I be doing with my car? Also, I was wondering about changing the transmission and rear differential fluids. My owners manual says these fluids need to be changed around 100K miles, but some mechanics say 50K. What do you think?
I have changed my own brakes, oil, air filter, and added other lubricants as seen necessary.
Mar 5, 2010 at 4:03 AM
LEGITIMATE007
  • 5,121 POSTS
I think your at a good time to change the fluids, also you will need to do a timing belt. and just an overall safety check on the suspension and you should be good to go
Mar 5, 2010 at 8:22 AM
DAGRAD
[quote:3a5bd4c1c0="legitimate007"]I think your at a good time to change the fluids, also you will need to do a timing belt. and just an overall safety check on the suspension and you should be good to go[/quote:3a5bd4c1c0]
Am I specifically changing the rear diff and transmission fluids?
Mar 5, 2010 at 8:25 AM
LEGITIMATE007
  • 5,121 POSTS
yes, and of course the tranny filter, and your other basic items, such as pcv valve, air filter, fuel filter, unless you've done some of these recently
Mar 5, 2010 at 8:29 AM
