transmission not shifting into overdrive at normal speed
65,000 MILES • 5.7L • V8 • RWD • AUTOMATIC
DGOSS6
On steady acceleration, trans. usually shifts into overdrive at 45-48 mph. Normal rpm at 65 mph in o/d was about 1500. Currently, the rpms stay about 2000-2200. I can feel the trans. shifting 1-2 then 2-3, but not 3-4. Gas mileage has dropped from 28mpg on the highway to about 21 mpg.
May 20, 2014 at 7:08 AM
HMAC300
  • 48,601 POSTS
have a trans guy look at it sounds like you have lost the lock up clutch in converter and probably o/d
May 20, 2014 at 8:15 AM
DGOSS6
Thanks Hmac300 for the quick reply. That's what I'll probably do.
May 20, 2014 at 11:33 AM
