My 2001 chevy corvette LS1 with 94k miles has a check engine code of 357. I replaced the coil pack on the 7th cylinder and reset the code, but it came back in a couple days with the same code. The car seems to miss a little and i can smell coolant under the hood after the car has warmed-up. There is no coolant under the vehicle, but I do have to add some occasionally. If I do a lot of stop and go driving and drive it hard, the temp gets up to 215 degrees and returns to 190 degrees. What is the problem(s)?
Oct 20, 2007 at 9:31 AM
