2001 Chevy Corvette battery
63,000 MILES • V8 • 2WD • AUTOMATIC
EMMANUEL RICO
my 2001 corvette, i jumped cables, and when and replaced the battery, now looks like i have elctrical problem when i turn on the car, some times rurns off by its self, and apears high voltage.. do you thing its the computer!!!!
Dec 2, 2009 at 12:06 AM
ERNEST CLARK
  • 1,730 POSTS
First, check for corrosion around the battery terminals. Then check all of the grounding points. (Negative battery cable to frame, Engine block to frame, etc.)
If all of these check out, then it is possible that while jumping your vehicle, a voltage spike fried your computer. But there would usually be a trouble code.
Have your computer scanned as your last step.
Jan 7, 2010 at 3:51 AM
