2000 Chevy Corvette overheating
100,000 MILES • V8 • 2WD • MANUAL
SITETRACK77
I have a 2000 corvette (c-5) recently my engine was running hot, temp guage indicated 220 degrees, I look at my rad. fans and it just turn off.
The vette seems to run hot when at idel and moving slowly as well.
Jun 4, 2009 at 2:31 PM
  • 75,988 POSTS
Try replacing the thermostat if it continues have it block and pressure tested.
I look at my rad. fans and it just turn off. lol-is the cooling fan coming on?? If not could be the caused of your problem.
Jun 4, 2009 at 2:37 PM
SITETRACK77
Thanks for your help, the fans are on but like i said they will turn off especially when it's getting hotter, they come and go on spariadically. I'm thinking thermostate switch!
I also have a leak with my water pump, which is being replaced with thermosate next week when parts come in.
Jun 4, 2009 at 2:50 PM
  • 75,988 POSTS
Could be the coolant temperature sensor or the engine temperature gauge switch and thermostat
Jun 4, 2009 at 3:33 PM
